how do you place ur Rolex when not in use?
  • #46
    Don't get too worry about it.
    • #47
      Originally posted by batamboy View Post
      I heard from a watch techician that resting watch on the crown will damage the mechanism directly. Its not advisable to do so.cos sometimes without knowing it,if we put the watch on any hard surface too hard,if the impact hits the crown too heavily, it will affect the movt cos the crown is directly link to the movt.
      Hmmm.....makes sense....does it matter is crown is open or wound down? :-)
      • #48
        Face up usually, if only for fear of scratching glass (I know it's meant to withstand more than an occasional push across the table, but still paranoid). Daily wearer in my bedside drawer (not on top, again for fear of accidentally knocking it off the table), the rest face up in the safe...
        • #49
          Originally posted by Jtaa05 View Post
          Hang around the neck of a bottle filled with water to prevent rubbing between metals.
          Wouldn't this cause to unnecessarily loosen your bracelet? I'm assuming a metal bracelet, of course.
          • #50
            Face up in my watch winder, didn't know facing up or down got impact on the watch movement.
            • #51
              Wow..didnt even know that it would affect the timing.
              • #52
                For me i keep all my precious in an individual Daiso $2 Spec Case with face up.
                New ROLEXY on the Blog
                Wishlist
                1) Yach-Master (16622)
                2) Explorer II - Black/White (216570)
                3) Submariner TTc (116613LB)
                Madness
                The ITCH is getting worse & incurable
                Repentance
                I let go my beloved U-Series Sub (16610) for the newcomers.
                • #53
                  Dial up position for me too. Does the position affect the rate of the clock?
                  • #54
                    dial up! back in the box
                    • #55
                      Any way that doesn't scratch it. Best is in a box.
