hybrid movement (and clone movement):
this warrants a different discussion. until 2014, i have always been under the impression that rolex parts do not fit into an eta movement. thus i used to tell people a quick tip to distinguish an ETA from a modern rolex movement is to adjust the time. clockwise = time goes forward on a rolex. the opposite for ETA. (30xx movements work the same way as ETA does)
check the date flick. if the crown height is correct (2824), then the date will flick over instantly on a real rolex movement (15xx and later models).
trust the chinese to figure out what works and what doesn't. you can apparently now stick rolex wheels into an ETA to make the time go forward when turning the crown clockwise.
in general, an ETA would have an etachron-type adjuster. more advanced versions may feature a triovis adjuster. but it is unlikely you will see a studded balance wheel (microstella screws) on an ETA movement.
the chinese have also been building a clone 3135 movement. there are at least 2 different versions on the market, possibly 3.
in general, pay attention to the balance bridge. there should be only one area sticking out on a genuine rolex movement. on the clones there are usually two. this is the limitation of the base calibre of these clones.
the clones allow a user to use a genuine rolex dial, hands, date wheel and some critical wheels (reversers, etc).
i have not had sufficient experience with these movements because they are, in my opinion, generally rudimentary and easily identified. but they CAN look very similar to a genuine 3135 movement for the uninitiated.
PAY ATTENTION TO THE BALANCE BRIDGE!
the future:
the maker of the fake watch i bought sent me photos of his latest 16610LV insert and 16610LV dial 2 weeks ago. he also published it on his own website.
the spacing error i mentioned earlier has been rectified. the dial looks really very very good.
the color of the insert, if the way he has described it, also looks fantastically close to some variations of the genuine part.
i believe the dial maker will eventually make a batch of these dials, when it is "perfected" by him, with the correct 3135 feet position.
because i use non-rolex crystals on some of my watches, i am unsure if this is a good or bad thing. on one hand, these dials will cost a fortune if sold by rolex. on the other hand, the quality is really really good... and it is cheap.
will i eventually be buying a perfect but "fake" 16610LV insert? (i use non-rolex purple and white inserts on my own subs/gmt2s).
i doubt i will get a fake dial, but i will probably get a fake insert. a real LV insert is US$450 from RSC... thanks but no thanks.
as technology advances, and the prices of rolex watches increase with time, you can be sure more and more people will be trying to "make a buck."
collectors of vintage watches cannot stop educating themselves unless they do not mind being ripped off from time to time.
if you know what you are buying, you will be less likely to get ripped off. i have experienced watch dealers that have sold me some fake rolex parts by accident before. because they have a good rep doesn't mean they won't make a mistake.
as always, caveat emptor!
the future:
