Hi All,
I found something interesting between Sea Dweller and Submariner. I have owned both M-series Sea Dweller and Z-series Submariner. I was trying to put the Submariner bezel protector (the round plastic ring) onto the Sea Dweller. Surprisingly, it does not fit! I thought both Sea Dweller has same 40 mm diameter with Submariner, but why the bezel protector from Submariner does not fit the Sea Dweller? I even tried the other bezel protector from my M-series GMT-Master II onto the Sea Dweller, it does not fit as well.
Has any of you ever tried it? Are Sea Dweller and Submariner really different, apart from the helium valve, thicker case and no-cyclops sapphire glass. Could anyone describe more differences between these 2 models?
